-   -   Low voltage problems!! (http://www.diychatroom.com/f17/low-voltage-problems-109161/)
bkm2570 06-29-2011 12:17 PM
When I hook up the low voltage to my circuit board on my furnace it drops from 24 to 5. I've tryed 2 differant boards and have a new transformer that reads 24 when not hook to the board. If you can help it would be great. Thanks!
beenthere 06-29-2011 06:14 PM
What VA is the new transformer.
Did you try leaving all other low voltage wires off, and seeing what voltage you read.
biggles 06-29-2011 06:37 PM
is the board tagged R and C backwards maybe with nothing connected you should read 24Vs where it connects to the board
hvactech126 06-29-2011 07:56 PM
sounds like a bad stat or another load that is shorted in the low voltage circuit. I've seen contactors in ac units cause this.
