Old 07-10-2010, 03:34 PM   #1
Low Voltage Help
Here are my components.
Goodman Furnace / GMVC950704CXa 95% AFUE 2-stage Variable Speed Gas furnace 70k btu
Goodman HP / SSZ140361a Split system heat pump 14 seer 3ton
VisionPro IAQ THM5421C / TH9421C1004
Hermidifier G-100ES Duct mount Humidifier Power flow through
Can somebody give me a road map of all the low voltages connections with the stat controlling the humidity. Also any dip switch changes that may be needed on the furnace
My available furnace contacts are
1
2
R
C
G
W1
W2
Y1
Y2
O
DEHUM
HP contacts
R
W2
O
Y
C
Can someone fill in the blanks for me?
EIM----------------- furnace------------------------ HP
R------------------------R---------------------------R
C------------------------C---------------------------C
O------------------------O--------------------------O
W1-------------------- ? --------------------- ?
W2------------------- ? --------------------- ?
Y---------------------- ? --------------------- ?
Y2--------------------- ? ---------------------- ?
G------------------------G------------------------
Also on the humidifier do I just hook my two wires to 1 and 2 on HUM?
Thank you in advance
Dave
daveyhouse is offline   Reply With Quote
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 10:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
