Low Clearance Dryer Vent Solution? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 06:53 PM   #1
Rewards Points: 1,646
Low clearance dryer vent solution?
I have my washer/dryer units that are located inside a closet outside in the car port.
Due to the depth of the closet there is not much room behind the dryer, to the point the dryer is pushed back in such a way the flex coiled duct is deformed/crushed to half it's original diameter.
Is there any special dryer vent fittings that allow for low clearance connections?
I found this online:
In my case, I don't want the outlet to be on "the other side". I understand this is done to offset the vent, but in my case the dryer is inside an outside closet, the wall the dryer is pushed against is an exterior wall, the other side is my kitchen. I want the outlet to be on the same side as the inlet.
miamicuse is offline   Reply With Quote
Old 11-20-2012, 07:42 PM   #2
a short straight dryer vent and your clothes dry much faster
mrairflow is offline   Reply With Quote
Old 11-20-2012, 08:41 PM   #3
Correct. But in my case, my dryer's vent opening faces an exterior wall, the other side of that wall is the INTERIOR of the house. I can't vent inside.
The dryer is in an outside closet, under a covered carport.
Old 11-20-2012, 09:43 PM   #4
Missouri Bound's Avatar
Outside? As in not heated or cooled?
Do you want it your way or the right way?
Old 11-20-2012, 09:51 PM   #5
It is an outside closet with a double door. The washer and dryer are inside, as is the lawn mower, and some tools.
So it is an enclosed space, not heated or cooled. Location is Miami, so it's always hot.
Old 11-20-2012, 10:06 PM   #6
And you can't just elbow it out the side?
Old 11-21-2012, 05:05 AM   #7
get a piece of 4 inch stove pipe and run up through the roof with a roof termination for dries http://www.dryerbox./
The Following User Says Thank You to mrairflow For This Useful Post:
Missouri Bound (11-21-2012)
Old 11-22-2012, 09:56 AM   #8
No, not with the low clearance behind the dryer, there is not enough space for an elbow.
So I need something that is really low profile to connect to the back where the dryer outlet is, then it it beyond the space behind the zone that is behind the dryer, once it's outside of that I can connect a vent to it and run it wherever.
Old 11-22-2012, 12:18 PM   #9
take a pic and post it might help
Old 11-22-2012, 07:26 PM   #10
Well..if that space isn't adequate for a dryer, it shouldn't be in there. AS mrairflow suggested, take a few pics.
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 12:08 PM
Dryer vent butterfly damper safe? TryHard Appliances 9 01-17-2011 02:44 AM
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 08:26 AM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
