Low Air Pressure From Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2009, 03:13 PM   #1
Low air pressure from vents
I live in a fairly new house and I find the air pressure is not that high from the vents on the top floor. Is there any way, besides pulling off all of the drywall and taping the joints, or adding another fan, to increase the pressure?
Would just taping the joints in the ducting in the basement make a significant difference?
swenard is offline   Reply With Quote
Old 08-21-2009, 03:30 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 180
Where do you live? You can close some of the main floor registers to boost the pressure upstairs. You should have a servicetech check the furnace to make sure the fan is on the correct speed and he may be able to speed it up a bit more. A heat rise test thru the furnace should be done along with the annual maintenance check.
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 09:48 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
