Louvered Doors And Gas Hot Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 11:22 AM   #1
Louvered doors and gas hot water heater
I am having a gas water heater, electric well pressure tank, and water softener installed in a wardrobe closet at my summer cottage. Is installing sliding doors that have louvered only on the top half good enough for air flow?
dvenne is offline   Reply With Quote
Old 05-03-2013, 09:09 AM   #2
Rewards Points: 2,212
Best to ask the one installing them. Especially for the Gas water heater which may have it's own air intake.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
dvenne (05-03-2013)
Old 05-04-2013, 04:50 AM   #3
An old Tradesmen
Rewards Points: 7,816
Code requires an in take high and low. So only on the top won't pass an inspection. A gas fired appliance in an apparel closet isn't a good idea. Lint is very combustible.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (05-04-2013), mae-ling (05-04-2013)
Old 05-04-2013, 08:30 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 150
I would go with an elec tank instead. Gas can be dangerous if fumes spill from it and you don't want them near any living area. If the room was sealed and had a pipe from outside to let combustion air in that would be better. with a cottage then you have to worry about squirrels etc getting in thru it. elec is the best for cottages.
Tags
air flow , gas hot water heater , louvered doors , safety , well premature tank
