07-17-2010, 12:28 PM
#1
loud thumping noise inside airhandler
What is a periodic loud thumping noise coming from the air handler during the air coindioning phase?
07-17-2010, 01:02 PM
#2
Hvac Pro
AWOL cat in the blower wheel. LOL.  You need to check inside the fan compartment and look into the fan to see if a piece of insulation or debris got in there and makes it off balance. The blower wheel could also be loose or damaged.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
07-17-2010, 02:02 PM
#3
the Musigician
Or the last guy that worked on it still trying to find his way out?
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
07-17-2010, 02:30 PM
#4
An old Tradesmen
Or too much clothing in the dryer sitting next to the air handler.
Could be the blower wheel is loose on the motor shaft. or the wheel could be out of balance.
07-17-2010, 03:01 PM
#5
You talking to me?
while not quite a thump but sheetmetal "pops" or bangs sometimes. Large panels do an oilcan action when pressurized and then when the pressure stops sometimes.
07-17-2010, 03:08 PM
#6
DM
Bwahahahahahahahahahahahah..~PLOP~...oops...laughe d so hard my head fell off!
Good one DM.
Just slow, not stupid.
07-17-2010, 03:14 PM
#7
You talking to me?
DM
It's Jack Bauer.
EVERYBODY GET DOWN!!!!!!!
07-17-2010, 03:16 PM
#8
Yuri is most definitely correct.
If I may expand on what he has already stated: All it takes is for a small piece of paper to be stuck either in side the blower wheel or the outer surface of the wheel.
It could cause an intermittent knocking of the blower. Or it could become stuck in the wheel and make a continous noise.
#9
the Musigician
Good one DM.
I KNEW that was you! How did you finally get out?
DM
07-17-2010, 03:19 PM
#10
the Musigician
I gotta go with nap on this one, a periodic thump says sheetmetal expanding/contracting to me. Debris or offset blower would be more or less continuous, right?
DM
07-17-2010, 03:21 PM
#11
DM
i went on a starvation diet and snaked my way out a cold air register
Smarty pants lol
07-17-2010, 03:32 PM
#12
DM
I would agree with the possibility but the OP described a "THUMP" not a "BANG" which is how I am used to hearing sheet metal expansion and contraction.
Last year I almost needlessly changed an inducer cause of an intermittent thumping.
But I wasn't 100% positive so I killed the power and pulled the inducer and put the stat to "fan on". The thump kept coming and going.
It turned out to be a cellophane cigerette package stuck to the outer surface of the blower wheel.
07-17-2010, 04:02 PM
#13
the Musigician
So, of course, you apologized for forgetting to clean up the last time and did not charge him, right? hehehehe
DM
07-17-2010, 04:04 PM
#14
You talking to me?
DM
Hell, he charged him extra. He did clean out the ducts after all.
07-17-2010, 04:10 PM
#15
the Musigician
ROFLMAO!
too funny....
DM
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
