Old 07-24-2012, 07:06 PM   #1
Loud return air grille
I recently had a second furnace/ac unit installed in my attic to cover the second floor of my house. The installer only used one air return in my ceiling for the new unit (20x20 grille). The problem is that the large volume of air moving through the grille causes it to "ring". Seems like it is due to the thin metal used. When I remove the grille I can hear the air movement but not the ringing sound. Is there a heavier grille cover made for a situation like this? Thanks,
Davidj2012 is offline   Reply With Quote
Old 07-24-2012, 07:09 PM   #2
CDH
Is there a filter in it?
CDH is offline   Reply With Quote
Old 07-24-2012, 10:34 PM   #3
An old Tradesmen
Angle the louvers out straighter.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (07-24-2012)
Old 07-24-2012, 10:40 PM   #4
You know doubt have a "stamp-faced" grille... though it is surprising that a 20 x 20 is humming from a unit sized for your top floor only. How big is this unit?
They do make better grilles... grilles with aerodynamic fins that don't resonate like yours does. I would get a better grille, or ask the installer to put in an additional return, like in the Master Bedroom.
TopTechnician is offline   Reply With Quote
Old 07-24-2012, 11:15 PM   #5
REP
Itsd not the "thin metal",Its the fact that the grille and most probably the return duct is too small.
Theres nothing like choking your furnace for the rest of its life.
REP is offline   Reply With Quote
Old 07-24-2012, 11:29 PM   #6
like already ask what size is the unit? if it is a varible speed furnace the fan speeds may not be set correctly. If it is bugging you extremly bad this is not a good solution but you can take needle nose pliers and open up the lovers to a more straight angle the noise will diminish as you open up the grill. This is a bandade to the problem of the grill being too small for the air flow which passes through it.
turnermech is offline   Reply With Quote
Tags
loud air return
Return Air Filter Grille maxtor HVAC 3 08-20-2011 07:47 AM
Noises (singing and rumble) at main return grille John_W HVAC 1 01-28-2010 05:40 PM
Loud air return grille - suggestions? chrisd HVAC 6 02-17-2009 04:25 PM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 11:00 PM
return grille farrington135 HVAC 2 07-20-2006 10:31 PM
