Loud Noises From One Zone Of Hot Water Heating System - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 03:47 PM   #16
An old Tradesmen
Rewards Points: 7,328
Disconnect one of the return springs on the basement valve.
Old 02-16-2014, 08:46 PM   #17
Rewards Points: 446
More than likely the basement valve is closing while the upstairs zone is still calling for heat. What you're hearing is water hammer in the basement piping which is caused by a sudden stop of the flow.
They make slower acting valves that close very slowly that would stop the noise. The valves you have now are "usually" spring loaded closing. Once the thermostat in the basement is satisfied the power is removed from the small motor that holds the valve closed and the spring quickly shuts the valve setting up a shockwave along the length of the piping.
old_squid is offline   Reply With Quote
Old 02-16-2014, 09:00 PM   #18
Rewards Points: 150
I second it.
hpyjack2013 is offline   Reply With Quote
Old 02-17-2014, 09:03 AM   #19
Rewards Points: 83
Interesting....I'll mention again that it only happens some of the time. I was checking last night and watched the valve when it shut. It was a slow gradual closing, like the first option you describe. And if I'm remembering correctly, the upstairs zone was still open at the time.
Hopefully I'll have time today to play with the manual controls on the valves (just found those last night) and try to replicate. In the mean time, any other thoughts or responses?
dvaupel is offline   Reply With Quote
Old 02-17-2014, 09:37 AM   #20
Rewards Points: 150
It may be that the zone valve is giving you a "warning" that it's going to become a headache. Until you can actual duplicate it or it does it several times where you can get a handle on it, It would just hang on. I"m I correct in that it looks like the zones are piped differnet sizes? 1-1" and the other 3/4" / It almost looks like it branches off from 1 to 3/4 and back to1"? Are you 100% sure it's the heat and not something else in the house. Does it happen certain times of the day or night or is it random? certain days of the week or any day.
Old 02-17-2014, 09:43 AM   #21
Rewards Points: 150
I'll admit I've been out of the game for a little while and things change, but are those valves closed on either side of the backflow preventer? and where is your automatic feeder located. I can't seem to find one in any of the pictures?
Old 02-17-2014, 09:46 AM   #22
Rewards Points: 150
does this heating system have or require any type of an expansion tank?
Old 02-17-2014, 09:47 AM   #23
Rewards Points: 3,764
But this is why these valves are directional. When the call for heat is done the motor shuts off and spring pressure acting AGAINST the flow of water closes the valve slowly and smoothly. If you put them in the wrong way (or there is a reverse flow for whatever reason), the flow will act WITH the spring and slam them shut.
@op
Interesting... I notice in the bottom picture the cross flow (bypass) valve is off. Is your pump wired to shut off when both valves are closed or does it run full time?
Bob Sanders is offline   Reply With Quote
Old 02-17-2014, 09:58 AM   #24
Rewards Points: 150
another thought- make sure arrow on circulator housing is pointing in the same directions as zone valve. I may have been wrong on pipe size could be picture distort, but they look bigger than 3/4" What type of heating "units" are they supplying: fined hydronic baseboard, cast iron baseboard, radiators? Is it a looped system where the hot water goes from the boiler to the first unit and then comes out of that one and on to the next or is there a loop run around the basement and back to the boiler and the water for the units is drawn off by mono-flow tees?
Old 02-17-2014, 10:01 AM   #25
Rewards Points: 83
Wow....lots to respond to here:
@hpyjack:
-Yes, absolutely sure it's the heat. No rhyme or reason to time of day/week/etc. But when the basement zone is on, to this point it's happened max 4 times a day, not every time it shuts off.
-Zones are piped differently. Upstairs is 1" for the first few feet, the has a T down to two 3/4" lines. Basement stays 3/4" the whole time. There is no change in pipe size aside from the T.
-The valves on either side of the backflow are closed. I don't know what an automatic feeder is. If I'm understanding your question, I'll respond by saying that it's a closed system. The only way new water is introduced is manually using those 2 valves by the backflow.
-Yes, there is an expansion tank above the boiler.
@BobSanders
-I've never understood crossflow/bypass. When the boiler was installed last year, that's how it was set up. I asked a quick question about it at the time, but don't recall the explanation I was given. I do know that the pump does not run all the time...it shuts off when both zone valves are closed.
Old 02-17-2014, 10:03 AM   #26
Rewards Points: 150
@op
Interesting... I notice in the bottom picture the cross flow (bypass) valve is off. Is your pump wired to shut off when both valves are closed or does it run full time?[/QUOTE]
where is the circulator control located? it looks like it is wired directly to the "service" switch.
Old 02-17-2014, 10:07 AM   #27
So the pump is running all the time, even when both zone valves are closed (no call for heat)?
Old 02-17-2014, 10:09 AM   #28
Rewards Points: 150
http://www.watts.com/pages/_products...s.asp?pid=3423
automatically keeps water in boiler and maintain water pressure
Old 02-17-2014, 10:11 AM   #29
Rewards Points: 83
-finned baseboard units
-yes, a looped system. Basement zone is one loop, upstairs would perhaps be counted as 2 (the T junction as described in my previous post)
-I don't see any arrows on the circulator. it's pretty close to the boiler unit, so it it's on the back side, I can't get a good view.
Another observation: When a zone valve opens and the circulator pump gets going, the water flows in the opposite direction of the arrows on the zone valve bodies. The arrows are pointing down towards the floor, but I can tell based on how the pipes heat up that the hot water is flowing up towards the ceiling. Not sure if it means anything, but I find it counterintuitive.
Old 02-17-2014, 10:11 AM   #30
Rewards Points: 83
No. it is not running all the time. Only when zone valves are open.
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Adding Zone to Baseboard Hot Water System bill8201 HVAC 3 03-25-2012 12:02 PM
Repairing converted Steam to Hot Water Radiator system - HELP! JonathonT HVAC 0 09-27-2011 09:08 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
