Old 07-01-2011, 01:13 PM   #1
Loud compressor, no cooling
I'm trying to help my sis in law with her A/C.
The compressor makes a very loud noise when it's turned on. The system is not cooling the home at all. It's about a 30 year old condensor.
Any tips on where to start or likely suspects?
thanks
brokenhammer is offline   Reply With Quote
Old 07-01-2011, 01:22 PM   #2
Hvac Pro
Compressor may be seized up or capacitor for it is weak. Need a electrical tester meter that checks capacitance or a Pro to check it.
Old 07-01-2011, 03:27 PM   #3
JJboy's Avatar
This noise can be the fan bearing.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 08:39 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 04:21 AM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
