07-10-2012, 08:09 PM
#1
A lot water on the drain panel
What do you guys use to remove the water inside of the drain panel?
1- Water pump
2- Wet vac
3- Scoop it out with a cup
I'm thinking about getting a small water pump....any thoughts
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
07-10-2012, 08:21 PM
#2
I give up....what is a drain panel? What is it on? What is it for? Pretty vague description. If I assume it's a drain for a cooling coil it should have it's own drain.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
07-10-2012, 08:24 PM
#3
Dude if you don't know what is a drain panel I'm not gonna tell...
Drainpan
07-10-2012, 08:28 PM
#4
[quote=JJboy;962667]Dude if you don't know what is a drain panel I'm not gonna tell...
Drainpan[/quote
So is it drain panel or drain pan? Guess YOU don't know either.
07-10-2012, 08:31 PM
#5
I didn't know drain panel is drainpan. well, I guess I learned something Today.
The Following User Says Thank You to clocert For This Useful Post:
07-10-2012, 08:34 PM
#6
07-10-2012, 08:37 PM
#7
Here.....circle the one you want help with..... drainpan - AOL Image Search Results
07-10-2012, 08:39 PM
#8
LOL I think you never get in this problem....I'm waiting...thanks anyway
07-10-2012, 08:42 PM
#9
You could be right about that. But it's unlikely you will get any answers until you clarify exactly what it is you are talking about...anyway, good luck
07-10-2012, 09:06 PM
#10
I found what I'm looking for:
http://www.youtube.com/watch?v=HXynn-J-TyE&feature=player_embedded#!
You guys learned something from me today. . Thanks JJBoy
07-10-2012, 09:50 PM
#11
An old Tradesmen
07-10-2012, 10:04 PM
#12
Originally Posted by beenthere
I used a similar today but I had to make about 4 trips. I was thinking to use a small water pump to pump the water to the primary drain line. I'm worried about any damaged for the client and speed the process.
07-10-2012, 10:35 PM
#13
is this the pan under the air handler shouldn't have water in it what going on with the one inside the unit.then run a PVC line out from the emergency pan to a stoop or back yard so they see water running when it over flows....and the emergency PVC is totally seperate from the uit drain line
07-10-2012, 10:47 PM
#14
An old Tradesmen
2 gallons taken out of the pan will get any drain pan drained low enough for the float switch to let the A/C run again. 120 degree attics will evaporate the rest of the water in a day or 2.
My tool bag weighs more. So no real worry about spilling water. plus, you can get the crap out of the trap that clogged it up in the first place.
The Following User Says Thank You to beenthere For This Useful Post:
07-10-2012, 11:15 PM
#15
I know that. The A-coil is cracked. The water is going straight to the drain pan instead of primary drain line. The secondary drain pan doesn't have drain line....but the flow safety switch saved for water damage.
The A-coil will be replaced.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
