Lost Screws On Trane Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 07:01 PM   #1
Lost Screws on Trane Heat Pump
While outside I noticed there are several screws missing from the side panels of my Trane Weathertron XE1000 heat pump condenser. I removed one of the screws and it is an unslotted indented 5/16 inch hex head screw that appears to be galvanized and about 1/2 inch long. I guess this is what is considered a zip screw. I am not sure if it is a #8 or a #10 screw. It has a sharp point. Does anyone know where to buy replacement screws for this unit? I went to the local Home Depot and Lowe's but they don't have an exact match.
homedoc is offline   Reply With Quote
Old 06-20-2011, 07:57 PM   #2
An old Tradesmen
Rewards Points: 6,470
HVAC supply house.
Old 06-20-2011, 09:49 PM   #3
beenthere:
Thanks for your assistance. I truly appreciate it!
Old 06-21-2011, 11:22 AM   #4
I tried to find the screws I need at several local hvac supply houses and they were unable to help me with the screws. Anyone know the part number for these screws so I can get my unit buttoned back up? Thanks!
Old 06-21-2011, 01:28 PM   #5
JJboy's Avatar
Duro Dyne
PPF 10x3/4
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-21-2011, 04:44 PM   #6
Dude just go to home depot and find something similar. No point on spending a ton of money on screws for the panel. Just make sure there are not longer don't wanna puncture the coil.
Hubcap626 is offline   Reply With Quote
Old 06-21-2011, 06:33 PM   #7
I have two of these units side by side. I only wanted all of the screws to match. I figured that some of the hvac professionals had come across this problem of a missing screw or two on a unit and could hook me up with some information on a replacement. My bad!!!!!
Old 06-21-2011, 08:35 PM   #8
An old Tradesmen
I get my spare screws from new RTU's, they have a bag with them for mounting the economizer. So on units that don't get one, i get spare screws.
Old 06-21-2011, 08:58 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
I would take a couple of the colored ones from an unseen side/area and put them where you want and use some generic ones where you cannot see them. You would have to order the OEM ones from Trane and that may be very expensive and logistically difficult.
Old 06-22-2011, 10:56 AM   #10
Good idea. I went ahead and purchased some #10 x 1/2" hex head self-drilling screws manufactured by Crown Bolt. The number on the box is 30282 in case anyone else runs into this issue. The screws worked and my unit is all buttoned up again. I appreciate all of you who gave advice and support.
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 04:55 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
