Losing Burner Flame And Pilot Flame - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 12:37 PM   #16
Wrong model number!!!!
Ok bad news, I talked with my tech and he says that I don't have that type of limit shut off, it would just shut off the main burner. I also found out that my model number was wrong, it is actually a DVCF653B. I thinks it a pilot oriface problem. He thinks the pilot is too big and that will give a low reading on the thermocoupler, so he is trying to find a new oriface for me now. I personally don't think this is going to solve the problem but it is kind of leaning towrards the only thing to that makes sense...some thing has to be telling the gas valve to shut down the pilot.
On a side note, the parts diagram calls for a Robert Shaw gas valve 7200ER part 72090, and they did replace that with a Honeywell in Dec 07.
Any other ideas?
papashaq is offline   Reply With Quote
Old 01-10-2010, 01:34 PM   #17
An old Tradesmen
Rewards Points: 6,544
How did the orifice become too big. Or did this heater never work right.
Old 01-10-2010, 02:37 PM   #18
JohnH1's Avatar
From the instruction manual. The overfired or loos cover areont the pilot would be the most likley problems.
Pilot and main burner 1. Weak thermocouple. 1. Check millivoltage and replace if low.
go out during normal 2. Input too high. 2. Check input rate.
operation 3. Cover around pilot lighter hole not sealed 3. Tighten wing nuts securing cover and sight glass. air tight. Check and replace gasket if needed.
4. Vent tubes not properly installed or 4. Follow instructions. Check both exhaust and air
sealed. intake tubes, and vent cap.
Be sure all gaskets are in place and properly sealed.
Use only tubes and vent cap supplied. Do not alter vent tubes or cap.
JohnH1 is offline   Reply With Quote
Old 01-12-2010, 02:03 AM   #19
Fixed
After much trial and tribulation I think it's fixed. If this makes sense...it was overfireing and that caused the pilot to get to hot (its very close to the burner) and eventually shut down. We check the manifold pressure and we got 3.5 wc which is what the manual specs it for, but we bumbed it down to 3.0 wc and has been working with no problems. Thanks for all the help guys.
Old 01-12-2010, 02:32 AM   #20
well glad its "fixed" but doubtful it has anything to do with an overheating pilot as its engulfed in flame and is frequently cherry red. sounds more like it was infact a limit issue the whole time
kennzz05 is offline   Reply With Quote
Old 01-12-2010, 05:58 AM   #21
An old Tradesmen
It was NOT over firing. If it was over firing at 3.5". Then it never would have worked right from day one.
All you did was cover up the problem. Not fix it.
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
Gas Fireplace Pilot Flame MicRos HVAC 2 11-01-2009 07:15 AM
pilot on, seems like burner not firing wombosi HVAC 1 10-15-2009 09:34 PM
Pilot flame...too big? timcoon HVAC 24 04-16-2009 01:21 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
