Loose Wires - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2007, 01:27 PM   #1
Smile
loose wires
hello guys & gals, i have a big problem
i have a comfort maker
model #guao8oao12aiin
serial#r884300150
it all started when the wheel cage went bad(squirrel cage).
i started to take the cage out,and two wires came off up top.
i quess its the controller
the model # is 50e47-843
now on this box,it has the word com(go from left to right)
mv2-yellow(connected
empty
grn-empty
th-gray(connected
mv1-red(connected
l2-yellow(connected
hs2-empty
fp-empty
hs1-red & blue-wire connected
to the lower far right corner of this box,has a small wire(black) about a inch long,thatsconnected to the box,but not connected on the other end(it only can plug in,but to what?
and a gray wire ,that ran for the box below,came up the side of the comfortmaker to the 50e47-843
i could surely need you help.........thanks
sixtythree is offline   Reply With Quote
Old 06-15-2007, 04:18 PM   #2
weekend warrior
Rewards Points: 150
can you post some photos, there should be a wiring schematic sticker somewhere on your machine as well.
johnny331 is offline   Reply With Quote
price for hooking up panel wires apeman76 Electrical 7 08-14-2007 03:04 AM
Running wires mt232 Electrical 4 03-22-2007 09:02 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
lighting lead wires tommygun32 Electrical 1 03-05-2006 11:10 AM
Short Wires sensen Electrical 3 04-01-2005 01:36 PM
