-   -   loose wires (http://www.diychatroom.com/f17/loose-wires-9169/)
sixtythree 06-15-2007 12:27 PM
loose wires
:thumbup: hello guys & gals, i have a big problem
i have a comfort maker
model #guao8oao12aiin
serial#r884300150
it all started when the wheel cage went bad(squirrel cage).
i started to take the cage out,and two wires came off up top.
i quess its the controller
the model # is 50e47-843
now on this box,it has the word com(go from left to right)
mv2-yellow(connected
empty
grn-empty
th-gray(connected
mv1-red(connected
l2-yellow(connected
hs2-empty
fp-empty
hs1-red & blue-wire connected
to the lower far right corner of this box,has a small wire(black) about a inch long,thatsconnected to the box,but not connected on the other end(it only can plug in,but to what?
and a gray wire ,that ran for the box below,came up the side of the comfortmaker to the 50e47-843
i could surely need you help.........thanks
johnny331 06-15-2007 03:18 PM
can you post some photos, there should be a wiring schematic sticker somewhere on your machine as well.
