Looks Like Mold Under AC Vents. What To Do? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2009, 03:49 PM   #1
Looks like mold under AC vents. What to do?
I went to switch the the direction of the vent so it would not blow on our little baby, and I found this... For now I sprayed it down with a bleach/water solution.
Is this as bad as it looks? Do i need to replace all the flex Ducting?
Luke
lucashugh82 is offline   Reply With Quote
Old 09-06-2009, 09:12 AM   #2
HVAC
IT IS AS BAD AS IT LOOKS!
For the supply vents and ducts to get this bad you have other issues with the A/C system.
Before doing any major duct work, you will need to find out why the mold got there in the first place, or it will just come back on any new or cleaned ductwork.
Call a qualified service company to find out why first.
Check other vents in home to see if they are as bad. If they are clean I would move the baby out of that room until this issue is resolved, seeing you don't know what kind of mold that is.
KAVF is offline   Reply With Quote
Old 09-06-2009, 02:47 PM   #3
JohnH1's Avatar
Did it clean up after the water and bleach? It almost looks like the inside of the boot is insulated with a dust build up on it. Is it insulated on the inside of the boot?
JohnH1 is offline   Reply With Quote
Old 09-07-2009, 10:56 AM   #4
We just moved into this house 4 months ago. House was built in 1991. New HVAC system installed in 2006.
It does have insulation in there that is black. The kitchen one is clean besides a little dust build up.
I have done two treatments of Bleach Water on both of the ones that I have pics of. I really cant tell if it did any thing.
I was going to try and find some white spray paint with anti mold fungal, and paint over it to see if the mold keeps growing.
Cant find any one open today because of the holiday... I guess I will be waiting tell tomorrow.
What could be the cause of the mold. Besides just living in hot humid Houston Texas.
Luke
Old 09-07-2009, 11:02 AM   #5
JohnH1's Avatar
Moisture is why. That is why it is insulated ot keep it from swetting. It looks like a tight fit but make sure the boot is a tight fit to the celing and dosent allow conditioned air to mix with attic air. Seal with mastic if there is any gap at all. Also check that any duct that is in a unconditioned area is insulated to prevent it from swetting.
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 09:48 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 06:56 AM
Removing some vents rdmccaw HVAC 4 10-22-2008 01:00 PM
