Looking To Update My Thermostat, Whats Compatable With My Carrier System - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 09:29 AM   #1
looking to update my thermostat, whats compatable with my carrier system
I have posted elsewhere sorry for a repeat ..
I have a carrier comfortzone II 4 zone system in my house. I want to upgrade my thermostat. Its a pain to program and latley its not holding the programming right..so i have to just hold temps on each zone
What t-stats are plug and play compatable with my system? I would love to get an infinity t-stat but is it compatable?
I just want to have to buy a t-stat not change any control boards... below is a link to my system... thanks!
http://www.residential.carrier.com/p...tzone-ii.shtml
detyianni is offline   Reply With Quote
Old 12-22-2010, 09:30 AM   #2
oh by the way Ive contacted different vendors and no one can give me a straight answer so i dont want to drop 200+ on a fancy tstat to find out it does not work... hopefully someone will have replaced a tstat on my system.. thanks again!
Old 12-22-2010, 03:06 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
ive looked at your link and if that one stat controls controls all your zones, then I know of NO available t-stat besides exact replacement that will control all zone from the one stat
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-23-2010, 04:48 AM   #4
Well if that's disapointing if that's the case....
Do I have a bad tstat? Here is the main issue...I painstakingly programmed it again last night and woke up to the heat on in two of my zones when no heat should have been on until 6am...
The hold function works fine ...so after some swearing I put hold on all zones and here I am.
Old 12-23-2010, 05:27 AM   #5
AKA HVACTECHFW
sounds like its mot being done correctly or a bad stat. Call a carrier dealer.
IT IS WHAT IT IS
Old 12-23-2010, 08:28 PM   #6
An old Tradesmen
Rewards Points: 7,356
Thats carrier/Bryant only. no other stat will work.
Old 12-24-2010, 12:00 AM   #7
Hmm ok so I email carrier direct to find a replacement they tell me to call carrier dealer...carrier dealers want to sell me a whole new setup when I just want the tstat...guess ill find the model number and start googling...
Old 12-24-2010, 05:41 AM   #8
An old Tradesmen
Carrier doesn't deal direct to with the general public. Only with their distributors and dealers.
Simply ask a carrier dealer if the stat is made anymore.
Old 12-24-2010, 04:50 PM   #9
Houston204's Avatar
Rewards Points: 556
It is sold as a set. Stat, room sensors, outdoor sensor and LAT sensor with a new zone control board.
Houston204 is offline   Reply With Quote
Old 12-24-2010, 05:06 PM   #10
An old Tradesmen
Well its about time you saw this thread.
have a happy holiday.
Old 12-25-2010, 01:39 AM   #11
Houston204's Avatar
Rewards Points: 556
Merry Christmas
Old 12-26-2010, 11:44 PM   #12
Thanks everyone...I managed to get a new tstat that is going to be sent to me...so last question on this hopefully...
One the new same tstat is there any configuration necessary except for the time or just wire it like the old one and I am all set?
Carrier a/c condenser fan motor still running slowly after thermostat is satisfied GetYourShineBox HVAC 18 06-14-2013 11:26 AM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 05:33 PM
do I need to use the infinity thermostat with the infinity system or can I use the edge aar HVAC 3 07-07-2010 06:42 PM
new system install.....questions firedogut HVAC 4 10-04-2009 07:10 PM
