Looking For Stats On “old” Unit – Help - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 05:44 PM   #1
Looking for stats on “old” unit – Help
I have a Inter-City Products YE036G heat pump manufactured 9/1993 and a GrandAire GB3BM-036K-A-10B air handler. I am assuming because of the reference to “36” in both units that these are 3-ton products, but does anyone know about what SEER they are? I am looking for replacements and would like to compare the current efficiency rating.
Thanks for the help!
Jason
jason24 is offline   Reply With Quote
Old 03-20-2012, 05:46 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
1993 would most likley be 9 seer at best. Todays minimum which soon will be extinct as well is 13 seer.
14 minimum as of two years from now.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 03-20-2012, 05:56 PM   #3
WOW, that was a super fast response. Thank you.
Potentially stupid question…
Why would a new unit with the same capacity, but more efficient (13 SEER) instead of whatever the current one is require a higher current breaker? (Going from a 30-amp to 40 or 45-amp on the condensing unit.) I have been quoted a PH13NA063000 heat pump and a PF4MNB037T00 air handler both are 3-ton, 13 SEER Payne products.
Old 03-20-2012, 06:12 PM   #4
An old Tradesmen
Rewards Points: 7,768
They are probably going by the Max circuit protection rating. The original installer may have used the min.
Old 03-21-2012, 09:08 AM   #5
I hear you.
Our Seer rating stays the same but we have to start using 90% furnaces, no more 80%
Crazy thing is every wholesaler is saying it won't happen in Mi.
Go figure.
hvac5646 is offline   Reply With Quote
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
