Old 07-14-2010, 07:25 PM   #1
Looking to run gas line to garage...plumber wants to know the BTU's
I'm having a plumber run several gas stubs in my basement. I've asked him to also run a stub to the garage in case I ever want to put a heater in there.
I guess the BTU's will determine the gas line size. The garage is about 15' x 40', unfinished, not insulated. Is there a BTU number I could give him and not worry about the line being under/over sized?
Thanks.
HautingLu is offline   Reply With Quote
Old 07-14-2010, 07:38 PM   #2
An old Tradesmen
Probably less then 60,000
Old 07-15-2010, 07:24 AM   #3
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Garage Door Install marly General Discussion 2 11-17-2008 03:51 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 08:57 PM
