Looking For Metal Filter Frame - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2011, 10:08 AM   #1
looking for metal filter frame
Looking for a metal filter frame with a hinged grille on it where you can lift up on the grille (it's hinged at the top) and replace the filter which is a 10 inch x 20 inch x 1 inch filter. The grille face is 12 1/2 inches x 22 1/2 inches and the building is a 1965-71 vintage structure, any thoughts help ?
cricket4321 is offline   Reply With Quote
Old 09-01-2011, 10:39 AM   #2
fabrk8r
fabrk8r's Avatar
Here's one source...kinda pricey though.
http://www.floorregisterresources.co...r-Filter-Grill
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-01-2011, 10:41 AM   #3
fabrk8r
fabrk8r's Avatar
The closest size McMaster-Carr has is 20"X14". If you can adapt your return to make it fit it may be worth it, they are about 1/2 the price of the other source.
Old 09-01-2011, 02:30 PM   #4
REP
Filter grilles are very common.Anyone that sells registers should be able to order you one for a lot less then that one shown.
REP is offline   Reply With Quote
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 05:49 PM
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 10:45 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Hog Hair Filter mjbxx HVAC 10 04-10-2009 08:46 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
