Looking For A HVAC Control Wiring Diagram - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 04:07 PM   #1
Rewards Points: 95
Looking for a HVAC control wiring diagram
I'm looking for a control wiring diagram for the following setup:
Single-stage Heil gas furnace
Single-stage Heil heat pump
Honeywell TrueSTEAM humidifer
White-Rodgers 1F95-1291 thermostat
A wiring diagram for anything similar to the above would help.
garya505 is offline   Reply With Quote
Old 10-09-2009, 07:55 PM   #2
newtech's Avatar
Rewards Points: 164
Model #'s would help
newtech is offline   Reply With Quote
Old 10-09-2009, 07:55 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Snoop thru here:http://www.goheil.com/go/index.asp?t=86&s=477
Old 10-09-2009, 11:01 PM   #4
Rewards Points: 95
Furnace is a NTG3FBF, single stage, single speed, 80%
Don't have the AC yet, but SEER 13 or 14 Heil HP, nothing fancy
TrueSTEAM will probably be the 6GPH model
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Sprinkler control wiring re-connect (diagram) ScottR Landscaping & Lawn Care 3 06-26-2009 01:25 AM
Sprinkler control wiring re-connect (diagram) ScottR Plumbing 4 06-25-2009 09:51 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Does this wiring diagram work? beezlebub03 Electrical 7 05-05-2008 12:54 AM
