Old 11-19-2007, 07:45 PM   #1
looking for geothrmal loop design
where can i look at a pond loop layout for 2000ft of 1/14 pipe i want to see how layout of piping would look in pond ,iam going to install own loop and contractor is going to install geothermal heat pump,i just need to see a design layout i have a guy that has sank them before going to help me thanks
cbprov is offline   Reply With Quote
Old 11-19-2007, 07:55 PM   #2
http://content.answers.com/main/cont...p_Close_Up.jpg
http://content.answers.com/main/cont...Being_Sunk.jpg
12 ton loop.
sams7267 is offline   Reply With Quote
Old 11-19-2007, 07:57 PM   #3
anything with more detail
Old 11-19-2007, 08:08 PM   #4
one person i was talking to told me i could use 4- 500 ft rolls of 1/14 pipe and run them 4 beside eack other and tie wrap them together so i would apx have a 16x 40 rectangle by thee time it is spread out laying flat looped on its side he said with going over sized pipe i did not have to run a manifold just loop them together joing at each end so it flows in 1 loop and through the next until it comes out of the last loop and back to the heat pump ,is this a recommended method or do you have to run the 4 loops in a manifold not one just a supply and return from all four loops that are tied in in a series thanks
Old 11-19-2007, 08:37 PM   #5
I wouldn't do it without a manifold. You need it dispersed for efficiency. The loop I showed you is one of the best pics I could find. It harder to make but better for your purpose and your "lake". It will spread the temperatures better than the design you are refering to.
Do a little research... you'll find a single oversized loop is hardly ever used.
Old 11-19-2007, 08:54 PM   #6
why is that thanks
Old 11-19-2007, 08:58 PM   #7
Old 11-19-2007, 09:12 PM   #8
Okay time to be honest , i had taken his design and had installed it in my pond which is now frozen over in the last week , the contractor was going to hook me up next week ,i have electric horizontal frurnace now, i had ordered a upflow geo pump they where going to install dampers so i did not have to take out my exist furnace the plenum was big enough ,is it worth the contractor hooking up the geo or should i wait for spring and rip it out and start over thanks for your advice,
Old 11-20-2007, 09:24 PM   #9
I hope that you fix it... it wouldn'y be all that hard to do. Thought I do understand not wanting to wait... maybe you could give your design a shot - there's more than one way to do anything.
Good luck.
How do you use a loop roller? redline Painting 8 04-02-2013 10:05 AM
studor vs. loop vent amakarevic Plumbing 8 11-15-2007 02:05 AM
loop vent or auto-vent amakarevic Plumbing 4 08-21-2007 01:28 PM
Boiler Primary Loop Choices Mike Warner HVAC 7 07-16-2007 11:01 AM
