-   -   Long range HVAC planning. (http://www.diychatroom.com/f17/long-range-hvac-planning-1860/)
dalesd 02-12-2006 08:58 PM
We're trying to make some long term decisions for heating and cooling our house. (and adding humidity in winter) It's a 1400 sq ft Cape, in Massachusetts. We have very cold winters, and hot and humid summers.
Our house currently has gas heat, forced hot air. We don't have central air. There's no humidity control.
In the summer, we use a few window air conditioners. (and, of course, fans.)
In the winter, we use a room-sized warm air humidifier. With the forced air heat, this seems to do a good job of getting the humidity spread throughout the house. It's labor intensive: it needs to be filled several times per week, and cleaned every week.
The gas furnace is an oil conversion. The conversion was done about 5-10 years ago (two owners ago). The 'gas part' (I'm blanking on the right name for it) is rented from the gas company for about $15/month. The whole furnace is sealed up, so it's impossible to inspect its condition. From what I've been told, these units made in the 70's were made right, and could last a very long time. Or the heat exchanger could fail tomorrow. We're kinda figuring it has 2-5 years left in it.
Would it make sense to add central air to the current setup? Or would it be wiser to wait (for it to fail?) and replace the furnace at the same time?
Also, what options are there for adding humidity to a forced hot air heat system? We're looking for something low to no-maintenance.
allan 02-13-2006 07:43 AM
Furnace replacement
It sounds as though the gas conversion furnace should be replaced.
Account for the rental from the gas company along with the probability that the existing system is inneffecient and that it mighy fail soon or alredy has and you have a good excuse to
change out this heating system.
As far as puttung in central air , consider that the furnace blower motor will probally have to be changed to a larger motors, but when you add a new furnace it will be the right already.
All these factors should be considered .
Do the math and you will see what i mean.
As far as humidty
a General 1042 blow thru should work fine for 1400 Square feet.
Allan Thorne
Clarkson Comfort Zone Heating and Air Conditioning Mississauga
weinstall.ca
dalesd 02-23-2006 12:37 PM
Thanks for the advice, allan.
