A Long DIY Project Coming To An End. Furnace Install - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 03:07 PM   #16
Originally Posted by bluefitness View Post
When he is finished, he will have saved a lot more than that. He did a complete cut-in, where as you did a change out. A cut-in involves every thing from running electrical to the panel to doing the duct work. A change out about a day to complete, while a cut-in can take 2-4 days to complete.
Right right..Its clear that his was more involved.
Tommy2 is offline   Reply With Quote
Old 12-01-2008, 03:56 PM   #17
Yeah, but your job was better cause you used a Tappan (just a little biased, not a lot. Just a little bit).
hvaclover is offline   Reply With Quote
Old 12-02-2008, 01:06 PM   #18
Rewards Points: 81
Originally Posted by beenthere View Post
Is that round flex, connected directly to the furnace.
If so, it doesn't give you good air flow.
If you have temp delta issues later.
You may want to put a square/rectangle to round transition on, to improve return air flow.
Connecting round to it like that, creates a lot of turbulance.
Probably gives you about a 100 to 150' equivalent length on that connection alone.
Just something to thing about.
The return flex is connected to the furnace with a small plenum and 16" starting collar made at a sheetmetal shop.
The 8" supply flex is connected via sheetmetal saddles for the 12" line that I custom made.
hartkem is offline   Reply With Quote
Old 09-22-2009, 10:18 AM   #19
Nice DIY project! What's the part number for the return grill? Where dod you buy it?
ee547kenny is offline   Reply With Quote
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 09:31 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Cost of installing Attic Furnace in new construction marejw HVAC 3 01-11-2008 04:00 PM
who should pay my gas bill and furnace repair? papashaq HVAC 8 03-09-2007 05:36 PM
