LOL, Is This My Furnace Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 03:37 AM   #1
Rewards Points: 83
LOL, Is this my furnace filter
OK, really lame question, but it's my first time dealing with a furnace. I just don't want to screw around with something that shouldn't be, or pull something out that I can't easily get back in. It's pretty snug.
Does this look like it's my furnace filter? I can't find anything else that could be it, but this piece just looks like wire mesh that is jammed in there. I thought they had an edge around them.
In this picture, we're looking just to the right of the bottom of the furnace near where the burners are.
darlingm is offline   Reply With Quote
Old 08-20-2011, 05:17 AM   #2
biggles's Avatar
it's stil a question no problem...yes it is your unit filter but very raw..take a trip to HD/LOWES with the measurement for a cardboard framed filter 1" most standard sizes 16 X 25...20 X 20...20 X 25..so see what fits.when you do get the new filter in cover that opening with plastic wrap strip of cardboard and tape it down..you want to pull the ducted return on the left from the space not around the unit...
Old 08-20-2011, 07:48 AM   #3
An old Tradesmen
Rewards Points: 6,470
Yep, thats a hog hair air filter.
Old 08-20-2011, 01:03 PM   #4
sktn77a's Avatar
Rewards Points: 390
It's a reusable (washable) filter. If you replace it with a 1" cardboard frame filter make sure it's a snug fit or you'll be leaking air around it.
sktn77a is offline   Reply With Quote
Old 08-20-2011, 08:02 PM   #5
Rewards Points: 83
Thank you everyone for your responses.
I think I found out why the previous homeowner(s) used this stuff instead of a better filter. The hole it goes into is 20" front to back and 16" deep. On the side close to us in the picture, it's 1" wide ... but on the side far away from us it's only 3/4" wide. Someone really paid attention here.
The 2-3" piece of metal in the picture to the left of the top of the hog hair air filter has a lip that's folder over the edge. I'm thinking if we popped that off, we could cut it so the hole would be a full 1".
Would that be the way to go?
You might be able to see in the picture, there's two indentations on this piece of metal. They aren't screws or nails. Is there a tool that makes a dent in the top piece, denting the piece under it, locking those two together or something? Do I just pry hard to get that off of there, and will I be able to get it back on?
Like I said, my first time. Thanks a ton!
Furnace filter recommendation? kcrossley2 HVAC 5 04-09-2011 05:17 PM
Rigged my furnace for a different type of air filter, bad idea? mibson HVAC 9 01-16-2011 01:11 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Wet furnace filter ??? dc4nomore Appliances 10 11-10-2008 01:24 AM
