Lock Out Due To Open Limit - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2007, 07:32 AM   #1
Lock out due to open limit
Sir,
I have a AirEase, Ulta V, Tech 80 furnace. My thermostat says its 66 the house I sent it to 70 and for the most part it wont keep the temp., it wont turn on and when I checked the code its blinking 6 & 4 flashes. According to the instructions it indicates that it is "locked out due to open limit". What would you suggest that I do to rectify this problem? I understand it may be a filter issue, but that's been changed 3 weeks ago. Please help.
Ariel
amortiz is offline   Reply With Quote
Old 03-03-2007, 10:32 AM   #2
It means that all the heat that the furnace is makeing is not being removed for ? reason.....bad blower motor? plugged filter!!!(most common) pluged evorator coil (very exspensive).
harleyrider is offline   Reply With Quote
Old 03-05-2007, 03:34 PM   #3
Electrical Engineer
Along with what harley rider said, make sure all of your vents are open, and there is no furniture blocking any return or supply vents. Make sure all of the return air grills are clean. Make sure that the blower actually turns on when you restart the furnace.
If you use a 1" fiberglass filter and change it regularly, there will still be a lot of dust that gets through over years of use. You can CAREFULLY vacuum the blower motor/wheel if it has a lot of dust on it.
rakes9720 is offline   Reply With Quote
Trane Open High Limit Device mdcheddarhead HVAC 3 03-02-2008 05:43 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
garage door lock jack_j General DIY Discussions 1 12-27-2006 06:40 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 11:33 AM
