Location Of Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 09:39 AM   #1
Location of Filter
Does it make a difference if my furnace filter is located in the ceiling return grill versus above the blower in the furnace itself?
imperial150 is offline   Reply With Quote
Old 12-02-2008, 09:45 AM   #2
Wethead's Avatar
I am not an expert but I think it makes no difference as long as its in the suction side .....
Wethead is offline   Reply With Quote
Old 12-02-2008, 10:15 AM   #3
If you keep it in the ceiling grill make sure you do not leave the filter opening uncovered in the duct above furnace.
My preference personally is to use the filter rack closest to he furnace just in case the return air ducts from the ceiling filter grill back to the furnace to furnace leaking and pulls in dust.
In that case the closer the filter to the furnace the cleaner the house stays.
hvaclover is offline   Reply With Quote
Old 12-02-2008, 03:24 PM   #4
Rewards Points: 109
More important than where it is located is what kind and size of filter you use. Most homes have to a filter with not enough surface area to pull the required air through. Don't use a 3M filter or any other super filter or this also restricts airflow.
Daltex is offline   Reply With Quote
Old 12-02-2008, 08:19 PM   #5
Say Bah- Bye jkl784
Furnace/Air Filter Cover bcme136 HVAC 14 09-25-2008 06:34 PM
Furnace minus filter dsal HVAC 16 02-24-2008 12:26 PM
Whole house water filter location Soloed Plumbing 2 02-04-2008 07:32 AM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 04:56 PM
