Location Of Connections For Carrier 25VNA HP - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 01:25 PM   #1
Location of connections for Carrier 25VNA HP
Where is the service panel for the field electrical connections located on the Carrier Greenspeed 25VNA heat pump - rear left corner or rear right corner of the unit (when looking at the unit face on with the Carrier badge at the front)?
I'm trying to plan out the mounting location (right side or left side) for the service disconnects ahead of delivery.
Pics of installs appreciated.
Thanks!
sixspeed is offline   Reply With Quote
Old 06-26-2012, 01:45 PM   #2
JJboy's Avatar
There are pictures in this post.
http://hvac-talk.com/vbb/showthread.php?t=951362
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-26-2012, 02:45 PM   #3
The one pic where I can see the refrigerant tubing suggests the left-rear corner. Is that the same for electrical?
Old 06-26-2012, 03:06 PM   #4
An old Tradesmen
Rewards Points: 7,730
The electrical panel is above the service valves.
pex connections Arky217 Plumbing 3 02-28-2012 11:54 PM
post location effect on cross bracing for deck/treehouse? martind74 Building & Construction 1 10-18-2011 12:45 PM
Location of expansion tank? speedster1 Plumbing 8 12-21-2010 03:50 AM
Encourage people to list their location secutanudu Site Help and Suggestions 0 09-15-2010 08:03 AM
