Little IAQ Project - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 08:37 PM   #1
Rewards Points: 85
Little IAQ project
OK,
Buying this house that was built in 2008. Well sealed. I never lived in a house like that before. Always lived in old drafty houses where I didn't worry much about the O2 etc.
Wondering if I'll need one of those automatic fresh air things. So I got a CO2 sensor on Ebay:
http://cgi.ebay.com/GE-SENSING-SAFEA...item3cba254056
$50, not bad. Of course, it has no display or anything, just a low-voltage RS232 interface. Here's the poop sheet:
http://www.tecnosens.it/media/6970/920-6603.pdf
The low-voltage RS232 adaptors are very common. I have a couple of them in the junk, but if I had to buy one, this one would probably work:
http://cgi.ebay.com/FTDI-USB-RS232-T...70148308148861
It comes with a set of double-female pigtails. I should be able to just
plug them into the CO2 sensor's connector. Or solder to it, no big deal either. I'll mount the sensor and USB adapter in a little plastic minibox with an airhole in front.
I'll plug the thing into a Linux box and write a little Perl script to log the readings every 15 minutes or so. After a week, I'll know whether opening doors is enough to keep the air fresh, no guesswork.
- JerryK
jerryk1234 is offline   Reply With Quote
Old 08-11-2011, 08:47 PM   #2
Not trying to be a jerk. If you are this worried about co2 then why not buy some houseplants?
Master of Cold is offline   Reply With Quote
Old 08-11-2011, 09:25 PM   #3
I don't think Jerry is worried about co2 except as an indicator of fresh air infiltration into the house. A stable co2 level of 1100ppm or less usually indicates enough ventilation to purge indoor pollutants. A low reading 500 to 700 ppm probably means too much ventilation(high energy bills).
Sounds like a cool project...co2meter sells a nice logger called aq100 that can log RH and temp as well.
Talbot3 is offline   Reply With Quote
Old 08-13-2011, 05:42 AM   #4
An old Tradesmen
Rewards Points: 7,808
Place it in your bedroom, and see if your CO2 remains low enough over night, when the doors aren't being opened and closed.
Timbertech Radiance Rail project Ranger1227 Project Showcase 7 07-29-2011 12:59 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Anyone used a project manager instead of GC? pulpit Building & Construction 10 02-11-2011 10:08 AM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
My basement project - a 2 year project. HABSFAN2006 Project Showcase 14 07-12-2009 09:30 PM
