Liquid Line Outside - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 09:28 PM   #1
GeraldR's Avatar
liquid line outside
The liquid line to compressor is 1/4, copper, no insulation on it, that's ok???
and it's fine to touch, except when I pulled the cover off the condenser unit, this line was too hot to touch right near the compressor!! is that okay??? or am in slow death????
GeraldR is offline   Reply With Quote
Old 07-17-2010, 09:39 PM   #2
HvacWiz's Avatar
Rewards Points: 252
All that you descibe is normal.
HvacWiz is offline   Reply With Quote
The Following User Says Thank You to HvacWiz For This Useful Post:
GeraldR (07-17-2010)
Old 07-17-2010, 09:40 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
The liquid line is supposed to be uninsulated and is fine. You probably touched the discharge line from the compressor and it is HOT and will burn you.
The Following User Says Thank You to yuri For This Useful Post:
Old 07-17-2010, 11:26 PM   #4
An old Tradesmen
Rewards Points: 7,376
Yep. The discharge line from the compressor will be very very hot.
The liquid line doesn't need to be insulated. Unless its run through an area that exceeds 135 on a regular basis.
The Following User Says Thank You to beenthere For This Useful Post:
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
Natural gas line????? figs Plumbing 1 06-14-2009 01:13 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 10:07 PM
