-   -   liquid line outside (http://www.diychatroom.com/f17/liquid-line-outside-76467/)
GeraldR 07-17-2010 09:28 PM
liquid line outside
The liquid line to compressor is 1/4, copper, no insulation on it, that's ok???
and it's fine to touch, except when I pulled the cover off the condenser unit, this line was too hot to touch right near the compressor!! is that okay??? or am in slow death????:furious::huh:
HvacWiz 07-17-2010 09:39 PM
All that you descibe is normal.
yuri 07-17-2010 09:40 PM
The liquid line is supposed to be uninsulated and is fine. You probably touched the discharge line from the compressor and it is HOT and will burn you.
beenthere 07-17-2010 11:26 PM
Yep. The discharge line from the compressor will be very very hot.
The liquid line doesn't need to be insulated. Unless its run through an area that exceeds 135 on a regular basis.
