Lining 6" Metal Flue With 4" Class B Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 11:41 AM   #1
Cobra64
Lining 6" metal flue with 4" Class B vent
I have an 80% gas furnace with a 4" exhaust attached to a 40 year old 6" double wall gas flue approximately 15 feet straight from basement to cap. It runs in a chase up the center of the house. A 4 " pipe runs approx. 5 feet from the furnace to the bottom of the flue. I have condensation running down the flue interior and from the reducer joint. The flue is clear. I could seal the joint, but then the water just ends up in the heat exchanger I would assume.
I am guessing the velocity of the gasses slows enough entering the 6" pipe to allow the condensation to form + interior surface area is too large to get warm enough to prevent it.
Can I ("within code") slide a 4" class b pipe inside the existing pipe? It will fit, just don't know if it is legal AND should that resolve the issue? OR is the only solution a condensation drain?
Thank you!!
Cobra1964 is offline   Reply With Quote
Old 12-03-2011, 01:39 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,426
It is legal. Our Pro chimney company slides smaller liners into 6 inch single wall liners all the time. Should have 4 inch B vent from the furnace to the chimney also. Loses a LOT of its heat on the way to the chimney. without it the moisture will run back into your furnace and SERIOUSLY damage it.
Old 12-04-2011, 02:14 AM   #3
REP
Using the old chimney as a chase is perfectly allright unless your hot water heater uses that old chimney.
REP is offline   Reply With Quote
Old 12-04-2011, 09:16 AM   #4
Hvac Pro
yuri's Avatar
depending on the combined BTUs of furnace and H2o heater 4" may be big enough to do both and be OK
Old 12-05-2011, 10:15 PM   #5
Cobra64
Thanks!!
Appreciate the input very much. Looks like a project for a weekend.
Cobra
Dryer vent with 4" PVC pipe rjniles Appliances 30 07-01-2010 09:21 AM
How to drill a 4" hole into brick for a vent??? firemanpato General DIY Discussions 10 01-17-2008 09:00 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
Source needed: 6" Vent Hood for siding STEPHENWANGEL Remodeling 8 09-01-2007 11:52 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
