Lineset Length - HVAC - DIY Chatroom Home Improvement Forum
Old 03-17-2012, 10:57 AM   #1
Lineset Length
I'm having my A/C replaced.. The installed says that he install a 20ft lineset. Since to get to me unit it is less (prob. 12ft) he will just make a loop in the lineset becuase a min of 20ft is always suggested. My old a/c does not have that, it just goes direct to the unit. Is this normal???? Or is he feeding me some BS???
RKory is offline   Reply With Quote
Old 03-17-2012, 11:05 AM   #2
An old Tradesmen
Rewards Points: 7,760
Most new units come precharged for a 15' line set. So he's slinging a little BS, or doesn't know better.
Old 03-17-2012, 12:16 PM   #3
If this is a pre-charged line set he may have to coil it up or cut it shorter.
hvac5646 is offline   Reply With Quote
Old 03-17-2012, 12:36 PM   #4
REP
It makes vwery little differance how he does it but to cut the line set may require two new brazed connections and anytime you eliminate a braze connection is usually a good thing.
REP is offline   Reply With Quote
Old 03-17-2012, 01:11 PM   #5
Yeah but, if you coil it it can make noise.
When we were using quick-connect Heil ac, a long time ago, I remember going on several nuisance call-backs for noise beacause Uncle had coiled the the excess linset up in the joists.
After that he bought exact length line-sets when ever possible.
Questions on replacing lineset OtherHand HVAC 6 04-26-2011 08:37 AM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
Lineset Install Einride HVAC 7 06-26-2009 07:00 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
total effective length question drewhart HVAC 2 01-27-2009 08:46 PM
