Lineset Install - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 06:47 PM   #1
Lineset install
Perhaps someone can give me a few pointers. I am installing a 2nd AC unit in my attic which will allow me to turn the 2nd floor into a separate zone. The existing York which cools the entire house was installed in 1985 and I will replace that with a smaller more efficient unit for the 1st floor after I complete the install in the attic. The 3/8" and 3/4" refrigerant lines for the new unit will run 20 feet directly up the outside of the house and enter through the siding into the attic. I have 2 questions:
1) I thought I would run the lines inside a standard aluminum downspout and use spray foam to seal each end. If there is a better way to do this, I hope somebody can let me know.
2) I am a little concerned about bending these copper refrigerant lines. How do you bend these lines without putting a kink in them? Any advice is much appreciated.
Thanks for the help,
Jim33 is offline   Reply With Quote
Old 06-03-2011, 03:41 PM   #2
Registered User
Rewards Points: 4,902
Welcome to the forum! I moved you to HVAC for a quicker response, someone will be with you shortly......
Gary
Old 06-03-2011, 07:18 PM   #3
I'd cut the back out of the downspout and just use it as a cover instead of routing the lines though it. Take your time on the bends and it's not hard to do by hand. Remember nice gentle curves, not tight 90's.
Old 06-03-2011, 08:52 PM   #4
An old Tradesmen
Rewards Points: 6,074
Down spout is used a lot for concealing line sets.
Myself, I use a bender. But use to do it ny hand years ago, just have to be real careful.
Old 06-04-2011, 05:22 PM   #5
Rewards Points: 1,214
Bender or it will probably kink. Buy a spring bender and use it where the line enters the building if your not experienced. If you can't get the bender off leave it on there and insulate around it. Pretty cheap for a nice bend no seams.
COLDIRON is offline   Reply With Quote
Old 06-04-2011, 06:42 PM   #6
20 feet high
Hi !
Since you are going up 20 feet with your line set,you will need a p-trap for the suction line in order for the oil to go back to the compressor.
No kidding.
Norlure is offline   Reply With Quote
Old 06-04-2011, 08:20 PM   #7
An old Tradesmen
Originally Posted by Norlure View Post
Hi !
No kidding.
The condenser is lower then the evap, no p trap needed to help oil return.
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 03:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 07:29 PM
