Lines Sweating - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 11:30 AM   #1
Rewards Points: 264
lines sweating
The refridge lines are wrapped in 3/4" i.d. x 1/2" wall K flex. Outside they run inside a soffit. I checked in there and the lines are sweating, enough that the condensation is dripping onto the vinyl soffit and keeping the space wet. The run is approx 30' from where it exits the interior to termination at the outdoor unit. The K flex is slipped on and sealed at the butt joints. The sweating is along the entire run. The home is in coastal Georgia, a very humid environment. I would appreciate any ideas on a fix.
Thanks!
7echo is offline   Reply With Quote
Old 09-06-2010, 03:13 PM   #2
might need thicker insulation or the line is frosting back.
Is it cooling ok?
hvaclover is offline   Reply With Quote
Old 09-06-2010, 10:52 PM   #3
Rewards Points: 264
The system is working well, cool and dry in the house.
Maybe I should just get a large enough i.d. foam insulation to cover the existing insulation? Would it be OK to cover the entire set, including the un-insulated line?
Old 09-07-2010, 03:22 AM   #4
I think so. It's been a hot humid one. AC working overtime would find the standard line insulation is not good enough.
Contact a supply house near you to find out the right thickness.
I'm a Northerner and even in this higher humidity my line insulation is good to go.
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 08:05 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 06:50 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
