Line Wire & Thermostat Wire Run? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 08:01 PM   #1
Line Wire & thermostat wire run?
Does it matter if i run the thermostat wire in the conduit drop with the line wire? I no noise affects Low voltage and i can surely just zip tie it to the outside but figure I'd ask since i dont really like the thought of just wires outside of it.
Tim
MNice is offline   Reply With Quote
Old 10-04-2011, 08:10 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I think I've only seen that done once. To the condenser, right? Usually the low voltage is taped to the insulation of the lineset but I don't think it'll matter on the inside of the whip with the high voltage wires.
Not sure of the code requirements on that either.
Doc Holliday is offline   Reply With Quote
Old 10-04-2011, 08:18 PM   #3
Rewards Points: 87
Originally Posted by MNice View Post
Does it matter if i run the thermostat wire in the conduit drop with the line wire? I no noise affects Low voltage ...
The thermostat is just switching 24VAC on and off. It's no big deal.
But best check code. That may not be allowed.
Jim
More Power! is offline   Reply With Quote
Old 10-04-2011, 08:18 PM   #4
Yeah the old wire that runs to the old condenser is tape to the line set. the old run all of it was zip tied to the outside of the conduit. Maybe I'll jus do it like the old one was.
Old 10-04-2011, 09:15 PM   #5
That's because when an a/c system is installed into a new home we run both copper lines side by side, insulate the suction line and run the stat wire with it, taped to the lines. Then we simply run the entire thing as one entity up and through a wall and into an attic or wherever the furnace is on the inside, from the outside where the condenser is.
That's just the way it's done, one shot but again, not certain the code on that. It may or may not be legal to do it the way you originally were thinking.
Yup, I'd just tape it and be done.
Old 10-04-2011, 09:30 PM   #6
No..you can't run the 240 volt and the 24 volt wire in the same conduit.
A sparky will be along shortly to reference the corresponding verse in the electricians bible.
Master of Cold is offline   Reply With Quote
Old 10-04-2011, 09:37 PM   #7
Not specifically talking about the A/C unit. I'm talking about the 120v line to the furnace.
Old 10-04-2011, 09:39 PM   #8
Same rule applies.
Old 10-04-2011, 09:49 PM   #9
party pooper.
Old 10-04-2011, 09:49 PM   #10
Rewards Points: 87
If memory serves (and mind you: I'm not a licensed electrician, nor do I play one on T.V.): You are not allowed to combine high- and low-voltage runs in the same conduit.
Jim
Old 10-04-2011, 09:52 PM   #11
Rewards Points: 6,652
I always use jacketed bell wire, that is at least 2 pair, so I have a extra set, in case something happens. Plus the jacket helps to protect the wiring. Now, there have been people that have taken panduit or loom to protect the whole run that the line set with the bell wire.
Old 10-04-2011, 09:52 PM   #12
Jim
Only if that lv controls that particular circuit, can you run it with it.
Remote sensor for line voltage thermostat? hbridge HVAC 7 07-06-2012 04:42 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 02:35 PM
Line voltage thermostat BLEW UP cupajoe HVAC 3 02-16-2010 10:30 AM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 12:52 PM
