Old 02-15-2010, 01:02 PM   #1
Exclamation
Line voltage thermostat BLEW UP
Hi,
I've got a line voltage (240V or 208V, I don't remember which) thermostat controlling an in-wall electric fan-driven heater that just blew up (the thermostat, not the heater!), leaving black streaks on the wall. It's worked fine for several years.
Any thoughts on what might be going on? I put this thermostat in myself a few years ago and it's definitely line voltage, 240V and an appropriate power rating (again, I don't remember the wattage, but I know I did check this) and worked fine until this incident. Before running out and just putting in a new thermostat, I'd like to get some opinions on this one. Thermostats are inexpensive, but condos aren't!
Thanks in advance,
Cupajoe
cupajoe is offline   Reply With Quote
Old 02-15-2010, 09:58 PM   #2
An old Tradesmen
Probably a short in the heater.
Old 02-16-2010, 07:20 AM   #3
Yea sounds like a bad heater
You will have to troubleshoot your heater before installing a new thermostat.
You need a volt ohm amp meter to to do this.
SULTINI is offline   Reply With Quote
Old 02-16-2010, 10:30 AM   #4
That's what I was afraid of. Thanks for the responses!
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 10:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Low voltage thermostat wiring dirtpig538 General Discussion 2 02-14-2009 01:48 PM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
