Line Set For Mini-split System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 01:19 PM   #1
Line set for mini-split system
Thanks in advance for your help.
I have a mini-split system being installed now, and the location of one of the air handlers requires a 75 foot line set.
The longest mini-split line set that I see is 50 feet.
Can I have one custom made for 75 feet?
Garrett
GarrettP1 is offline   Reply With Quote
Old 10-25-2011, 01:22 PM   #2
HVAC Tech/Owner
Rewards Points: 604
The installer adds to whatever the basic sizes are (25,30,50 feet) to get to necessary distance IAW manufacturer's instructions
Technow is offline   Reply With Quote
Old 10-25-2011, 01:41 PM   #3
Rewards Points: 154
mini-split
Make sure the installer weighs in the charge.
Patrick Eubanks is offline   Reply With Quote
Old 10-25-2011, 02:56 PM   #4
Thanks for the quick reply.
I called the manufacturer, and the length of 75' is no problem, but they don't make a line set in that length.
I guess I am concerned about how secure the connection will be joining a 50' with a 25'.
Since this is a new house construction, if that line leaks it's not going to be easy to fix.
That's why I was wondering about having one continuous line made that is 75'.
Should I have the connection brazed after joining?
Garrett
Old 10-25-2011, 03:12 PM   #5
HVAC Tech/Owner
Rewards Points: 604
If it was my house I would braze and leak check.......No connections behind walls.....
split system, high humidity pauli HVAC 34 08-19-2011 04:20 PM
Whats a good 3ton Heat-Pump split system to buy? ehoez HVAC 6 07-14-2011 09:11 AM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 09:54 PM
Replacing Split System and need help. Thanks. FunkedOut HVAC 0 08-12-2009 01:43 PM
installing a split system Jacques HVAC 6 07-10-2008 08:50 AM
