Old 03-09-2013, 10:53 AM   #1
Line set max length
Placing components on my drawings - is there a max recommended line set length? If it matters it will be a 2 - 2.5t hp, depending upon the calcs.
ratflinger is offline   Reply With Quote
Old 03-09-2013, 11:05 AM   #2
I'm Your Huckleberry
Line set max length
I've been told it was 100' max but I've never seen one that long. Make sure you've pulled a vacuum down to 500 microns and charge by subcool or superheat.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ratflinger (03-09-2013)
Old 03-09-2013, 11:22 AM   #3
An old Tradesmen
Line set max length
Each manufacturer will have their own max line set length. So you need to check with the manufacturer your specing.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
COLDIRON (03-10-2013), gregzoll (03-09-2013), ratflinger (03-09-2013)
Old 03-09-2013, 12:50 PM   #4
Hvac Pro
Line set max length
50 feet is usually the best option. after that you have to upsize the suction line and that gets VERY expensive as larger copper is VERY expensive. shorter line sets are always better for the compressor as you get better oil return to it and makes it last longer.
The Following 2 Users Say Thank You to yuri For This Useful Post:
COLDIRON (03-10-2013), ratflinger (03-09-2013)
Old 03-09-2013, 03:00 PM   #5
Line set max length
Thanks everyone - the quality answers I was looking for!
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 05:32 PM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 08:09 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 09:09 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
