Line Set Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 12:34 AM   #1
Line set installation
Hi, I installed a new hi efficiency furnace and central air unit in my home and have everything done except running and connecting the line set. I had two different contractors come out and charge me 50 bucks each for an estimate and then give me an estimate that was ridiculously high. the first guy we later discovered by searching the internet was scamming people left and right advertising free estimates if he does the work, then giving an insane estimate. Basically getting 50 bucks for doing nothing. The second guy that came was kinda my fault because I told him the price the first guy quoted ($1650.00) so he thought he'd get the work if he quoted $1250.00.when I told him no thanks and I would see him out he dropped his price to 9 bills then to 8 bills his argument being he had the tools to do the job. Well for less than half that amount I can get a manifold and a bottle of nitrogen,hoses and brazing rod and and do it my self if I have to.
My question is what is a ballpark guess at a price for this job. The AC unit is matched set mfg. by York. it is a 3 ton R410A unit with a charge for smallest indoor coil and 15 foot lineset. All I need is for the TXV (customer supplied) and the Line set, 3/4 X 35'(contractor supplied)
installed and add needed refrigerant. The run is easy access from the OD unit thru the attic to the ID unit in the furnace closet. (about 31 feet) I figure about 2 hrs work if the guy takes his time. Thank You
buck_e is offline   Reply With Quote
Old 07-16-2011, 12:45 AM   #2
JJboy's Avatar
I see you manage very well.....buy the equipments and do yourself. This is DYI. I'd like like to see you talking to a doc.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-16-2011, 01:03 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
You rang?
Just messing with you, JJboy.
Out. I have two condensers to set in the morning, speaking of linesets..
Doc Holliday is offline   Reply With Quote
Old 07-16-2011, 01:09 AM   #4
JJboy's Avatar
Originally Posted by Doc Holliday View Post
You rang?
LOL
Old 07-16-2011, 07:26 AM   #5
Rewards Points: 1,214
Remember another thing when you find someone to do the work at a reasonable price it won't have a warranty mechanics do not give warranty's when other people buy equipment and install it then ask for a warranty.
I however give a warranty on homeowner purchased equipment which reads " if the equipment breaks in half the owner gets to keep both half's"
I also offer another warranty it's called the egg timer warranty when the customer pays the bill I take out the egg timer and put it on the table when the material reaches the bottom I pick it up and leave.
COLDIRON is offline   Reply With Quote
Old 07-16-2011, 07:30 AM   #6
Rewards Points: 292
You forgot the vacuum pump.
veesubotee is offline   Reply With Quote
Old 07-16-2011, 08:39 AM   #7
An old Tradesmen
Rewards Points: 6,086
Your time estimate is wrong.
Probably somewhere between 1300 and 1800 for that job.
If you want it for less. Provide and run the line set yourself, and also provide the TXV. Then you just pay for brazing, nitrogen use, vacuum time and equipment use, and for the extra R410A. Probably get you below 750.
Old 07-16-2011, 10:26 AM   #8
Nitro is cheap. Vacuum pump,copper, brazing rod, torches,manifold,txv and micron gauge add up fast though. Last time I looked a small tube of 15% silphos was almost $170,they don't sell it by the stick, and a micron gauge is around $200. Best advice for saving money is do as beenthere said run the lines yourself then pay for the connection , vacuum and charge.
Old 07-16-2011, 11:12 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,098
You also need a multitester and clamp type thermocouple to check the liquid line temp for measuring subcooling or buy the $500 multifunction refrigeration manifold with all the bells and whistles. Not as cheap or easy as it sounds.
Old 07-16-2011, 11:53 AM   #10
An old Tradesmen
Fieldpiece SMAN3 manifold about 400 bucks, optional hoses you "need" to use it, roughly 80 bucks. Vacuum pump, about 360 bucks.
Old 07-16-2011, 12:03 PM   #11
Hvac Pro
yuri's Avatar
Knowledge of how to weld to the service valves w/o destroying them and ability. Priceless.
Old 07-16-2011, 12:08 PM   #12
JJboy's Avatar
He will figure out, he can do it in 2 hours LOL
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 09:09 AM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
