In Line Register Box? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 02:23 PM   #1
In line register box?
I am wanting to put a register above my basement bar, and I have a 6 in. heating duct running above it already. I was wondering if they make an in line register box. I can't seem to find anything on-line, and don't want to run around looking for something that may not exist.
nailbender1979 is offline   Reply With Quote
Old 03-14-2011, 02:31 PM   #2
Experienced
Jackofall1's Avatar
Hi and Welcome nailbender1979, to the best darn DIY'r site on the web.
Don't know about a register box specifically, but they do have a simple "T" saddle type fitting at the big box apron store.
You could always make your own, this is always an interesting venture.
Just remember that what ever duct you are tying onto, will transmit the sound and smells from your bar to that room.
Mark
Old 03-14-2011, 02:36 PM   #3
Thanks for the welcome! I have been browsing around, and this sure does seem like a great site. You bring up a great point about the smells. We smoke in the basement, but not upstairs. That would definitely drag more smoke up there. New plan time. Thanks again
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Questions regarding AC coil condensate line lassiter1979 HVAC 1 03-14-2010 08:47 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
