Is The Line Presssure Too High ? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 09:18 PM   #1
Is the line presssure too high ?
Routine maintenance of my AC, Tech checked pressure and in house air temp. He said the charge is a little low, so he added a little freon. He said I got 17 degrees in house temp split, everything looks good. But when he checked the line pressure, I saw 80 on the low meter, 280 on the high meter. Isn't that a little too high ? I heard the normal numbers should be 70 and 200. WHy did he say every thing looks good ? By the way, I have a 3 ton Goodmen, 8 years old, today's outside temp is 95F.
sh1633 is offline   Reply With Quote
Old 06-16-2012, 09:27 PM   #2
JJboy's Avatar
You have to trust your Tech.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-16-2012, 10:38 PM   #3
An old Tradesmen
Rewards Points: 6,560
200 would be low when its 95 outside.
Old 06-22-2012, 07:45 PM   #4
High side pressure
From what I have read 40% of hvac systems are not properly charged. I use an electronic superheat/sub cooling meter and the proper factory chart to do a fill within 1 degree of needed charge. Meter reads out super heat directly ands allows adding or removing the right amount of charge.
ONEOLDCROW is offline   Reply With Quote
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 11:18 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
Proper gas line installation for wall furnace rsaritzky Plumbing 2 11-20-2010 01:39 AM
