Old 06-30-2010, 07:35 AM   #1
Line length & Air handler dimensions
For a two ton split system, is there a maximum or practical length for the lines between the units? One story house in FL, AH in attic and condenser outside on slab.
I want to install an AH horizontally in my attic with very limited space. Do any brands have a smaller air handler? Width and depth would be important numbers. Is there anywhere to look this info up?
JIm
jjrbus is offline   Reply With Quote
Old 06-30-2010, 09:54 AM   #2
JIm
You really need to get the installation manual to get this information. Manufacturer's can allow runs up to 150' but there are often special requirements for the diamter of the liquid and suction lines.
Vertical runs can also affect this.
hennyh is offline   Reply With Quote
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Natural gas line????? figs Plumbing 1 06-14-2009 02:13 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
