Limit Switch Problem On Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 11:31 AM   #1
limit switch problem on heater
my lennox heater is showing the limit switch as being open. the blower works but there is no flame and the gas is turned on.how can i fix this?
the3cfam is offline   Reply With Quote
Old 11-08-2011, 01:27 PM   #2
Replace the limit.Change the filter and check that the evap. coil is clean
Old 11-08-2011, 07:47 PM   #3
A bit more time for a better answer... Limits trip because a furnace overheats. They can only open and close so many times before they are ruined. Overheating is caused by incorrect gas pressure or not enough air flow. Dirty filters or dirty coils are the most common causes but a failing motor or weak capacitor can also give low air flow. That should get you going in the right direction.
The Following User Says Thank You to Marty S. For This Useful Post:
Snav (11-08-2011)
Old 11-08-2011, 09:11 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,420
Undersized ductwork and people closing registers in unused rooms and restricting the airflow also is a problem. Only proper way to know is to get the gas pressure checked and temp rise thru the unit tested by a Pro.
Old 11-08-2011, 10:04 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
Some of those limits are resettable, some manually and some intermittenly (self resetting) if you will, but that doesn't mean that it won't trip again. The limit is simply telling you that something is wrong, of an overheating issue which needs to be addressed.
Doc Holliday is offline   Reply With Quote
Heil Gas Furnace Ultimate II - High Limit Switch Triggering Problem hiei5 HVAC 11 07-24-2011 01:23 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
any problem with cold water branch before water heater? jasperjodo Plumbing 3 06-08-2011 09:01 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
