Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 05:52 PM   #1
limit switch
I have a 1970s carrier ac/gas heater on roof of house, model# 48DL004, series#300, serial# H252538. During the summer blower motor burnt out, I replaced motor and ac worked fine. Now it is starting to cool down for winter, heat does not come on, traced problem (maybe) to 3" hi-limit switch, went to parts store, was told that this part is obselete can not get one, is there a way to by-pass switch to get heat into house?
dennis herm is offline   Reply With Quote
Old 11-10-2010, 05:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
Post a pic of the limit switch. Carrier is pretty good at having parts, probably need a different parts house. NO you cannot bypass it /major fire hazard/void house insurance etc.
Old 11-10-2010, 07:38 PM   #3
Ouch!That'll leave a mark
Never bypass a limit control!!! You could wake up dead!!!
ridgevilleac is offline   Reply With Quote
Old 11-10-2010, 10:04 PM   #4
An old Tradesmen
Rewards Points: 6,148
A limit that has never opened, doesn't go bad. So your limit has been opening. And saving your house from burning down.
Might want to find out why it has been opening before you replace it. just to have the new one go bad.
Its is around 40 years old. So your heat exchanger could be cracked.
Old 11-11-2010, 07:57 AM   #5
HVAC / Plumbing
1970's. It's time to upgrade & save some $$$$$ on the gas bill
kenmac is offline   Reply With Quote
heil 9000 limit switch problem? barryatnewton HVAC 1 01-02-2010 06:44 PM
Natural Gas Furnace Limit Switch 04gt HVAC 5 12-12-2009 08:50 AM
fan limit switch wiring to coil? honeywell luvheat HVAC 0 12-12-2009 04:03 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
