Limit Control Switch Help - HVAC - DIY Chatroom Home Improvement Forum
Closed Thread
Old 01-12-2009, 03:18 PM   #1
Angry
Limit control switch help
Does anyone know how to bypass a limit control switch so that the thermostat will still kick the blower on and off?
Last edited by farnsworth6406; 01-12-2009 at 03:24 PM. Reason: Had to re-word post
farnsworth6406 is offline
Old 01-12-2009, 04:01 PM   #2
Bypassing safety switches is very dangerous and not recommended.
SKIP4661 is offline
Old 01-12-2009, 05:24 PM   #3
Why do you want to bypass the limit?
hvaclover is offline
Old 01-12-2009, 05:35 PM   #4
An old Tradesmen
Rewards Points: 6,906
Not something that should be done, even if you only want to run the blower to circulate heat, from another source.
Too easy for someone to accidentally, turn the stat up to use the furnace.
beenthere is offline
Old 01-12-2009, 10:09 PM   #5
thermostat controls the burner not the blower. You can put the blower on the "on" position which will run 24/7 but the burner limit should never be bypassed.
thelimit is offline
Old 01-13-2009, 11:07 AM   #6
It is an old fashioned thermostat. It doesn't have an on/off. You turn the dial to the desired temp. That's it.
Old 01-13-2009, 11:14 AM   #7
Also this is a wood furnace, not gas.
Old 01-13-2009, 11:20 AM   #8
WOOD BURNER?
And you want to bypass the limit? Sorry we don't give info that will kill people
and cause house fire.
To knowingly by pass a safety limit is a felony.
Old 01-13-2009, 11:40 AM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thread Closed due to unsafe and dangerous nature of subject.
- Build Well -
AtlanticWBConst. is offline
Closed Thread
fan limit control question sbriggs_1 HVAC 2 12-11-2008 07:09 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
