-   -   Limit control switch help (http://www.diychatroom.com/f17/limit-control-switch-help-35755/)
farnsworth6406 01-12-2009 03:18 PM
Does anyone know how to bypass a limit control switch so that the thermostat will still kick the blower on and off?
SKIP4661 01-12-2009 04:01 PM
Bypassing safety switches is very dangerous and not recommended.
hvaclover 01-12-2009 05:24 PM
Why do you want to bypass the limit?
beenthere 01-12-2009 05:35 PM
Not something that should be done, even if you only want to run the blower to circulate heat, from another source.
Too easy for someone to accidentally, turn the stat up to use the furnace.
thelimit 01-12-2009 10:09 PM
thermostat controls the burner not the blower. You can put the blower on the "on" position which will run 24/7 but the burner limit should never be bypassed.
farnsworth6406 01-13-2009 11:07 AM
It is an old fashioned thermostat. It doesn't have an on/off. You turn the dial to the desired temp. That's it.
farnsworth6406 01-13-2009 11:14 AM
Also this is a wood furnace, not gas.
hvaclover 01-13-2009 11:20 AM
WOOD BURNER?
And you want to bypass the limit? Sorry we don't give info that will kill people
and cause house fire.
To knowingly by pass a safety limit is a felony.
AtlanticWBConst. 01-13-2009 11:40 AM
Thread Closed due to unsafe and dangerous nature of subject.
