Lights Blink - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2009, 09:06 PM   #1
lights blink
Ive noticed when the heat cuts on the lights blink just 4 a second. But ive never noticed it before.Been in this house 4 2 years.. any ideas
cdundon4va is offline   Reply With Quote
Old 12-01-2009, 10:00 PM   #2
by lights do you mean your house lamps, pot lights, etc.? If so I would assume it's due to the high draw of electricity to power on the hvac system. Believe it or not, I live in a brand new subdivision, with new fiber and under ground electrical, and during the summer, I can tell when my neighbor's ac kicks on because my lights will dim for a split second. It's wierd becuase when my ac turns on, I don't seem to notice the light flicker, but tbh, I haven't blown any fuses so I pretty much try not to worry about it...if it aint broke....no what i mean?? =)
Guam is offline   Reply With Quote
Old 12-01-2009, 10:03 PM   #3
4 years ?
2 years ?
42 years ?
What kind of heat ?
Old 12-02-2009, 05:22 AM   #4
been here for 2 years its electric heat pump.Just thought it was going to be a problem since it hasent done it before.
Old 12-02-2009, 06:03 AM   #5
Probably a weak capacitor.
Old 12-02-2009, 05:32 PM   #6
You can check your incoming 240v connection integrity with an elec. dryer or cooktop. When you turn off the cooktop or dryer, the 240v measured at the panel shouldn't increase by more than 1/2v or so.
Checking the cap requires a digital voltmeter, a 9v battery and any 1 megohm resistor.
Old 12-02-2009, 06:48 PM   #7
How do you tell if a capacitor is within +/- 6% of the named value that way?
Old 12-02-2009, 07:38 PM   #8
Using a DVM with 0.6% or better accuracy. But, usually the tolerance on the cap is looser.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Outdoor lights (Soffit etc) DIY_JC Electrical 2 09-25-2009 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
