Old 10-15-2011, 10:30 AM   #1
light gas pilot
How do I light the pilot for Goodman heater, model #GD880703AXCB?
momques is offline   Reply With Quote
Old 10-15-2011, 11:31 AM   #2
biggles's Avatar
light gas pilot
not knowing the unit i go that its a standard relite ..if it is a standing pilot set the gas valve to pilot push down and light the pilot area(main gas will not come on ) till the pilot holdsas you release the push down dial then you turn the valve to ON with the stat callingmain burner.... if it doesn't light no big deal stat isn't calling.thin stick with match taped to it makes for east reach in when lighting the pilot deep in the burner section....
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 08:49 AM
pilot light confusion please help fastcarsca1 HVAC 4 10-04-2008 03:44 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 06:16 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 10:26 PM
