Lifting Condensing Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 07:45 PM   #1
Lifting condensing unit
I need to raise the grade at my existing condensing unit by 8". Can this be done safely without first pumping down the refrigerant and disconnecting the refrigerant lines? If so what is the best way to accomplish this? The unit sits on 4" high legs that are place on a composite pad; it is a relatively new installation (less than 10 years old) and I have clear access on the front and left side with about 24" clear on the right and 12" on the back with plenty of 'slack' with all connection points which are located in the back right corner of the unit.
cbellinger is offline   Reply With Quote
Old 04-10-2012, 07:55 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Depends on how much copper lineset you have and how careful you are in the process of lifting the condenser. It's always risky without actually cutting the unit loose from the lineset which would entail pumping it down. Once you bend/kink the copper you will have to cut it loose and have it repaired.
Take and post some pics?
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
plummen (04-10-2012)
Old 04-10-2012, 08:35 PM   #3
Rewards Points: 582
best way and safest pump it down remove from area to be graded have it reinstalled.....
Old 04-10-2012, 10:04 PM   #4
biggles's Avatar
if you have room between the back on the condenser and the house cinder blocks layed down between both 3/4 piece of plywood cut to catch the feet..just lift the condenser up on that.do your grade put pad down lift it back down..lifting the condenser build a 2 X 4 form that wraps around the just below the top section real tight so it catches the screws on the unit.with extended pieces a guy on each side can lift it with ease grabbing the extended handles..doing a straight lift up.clear the lines so they rise with the condenser watch that 208V and STAT electrical if anything gets disconnected clear that stuff away from the condenser.recover/reclaim, revac, recharge your talking BUCKS... with all those REs
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
condensing unit shuts after 5 mins tboca007 HVAC 1 08-25-2010 04:30 AM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
Condenser unit quits working on regular basis.. big-e HVAC 16 07-22-2010 05:44 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 03:59 PM
