Life Expectancy Of Residential Central Air - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 09:07 PM   #16
Missouri Bound's Avatar
No heat with this unit? Hmm....that changes things a bit. Gas fired units have heat exchangers which MAY last 15 years. If it's cool only that doesn't come into play. The efficiency is what does come into play here, plus the fact that you probably have R22 which is being phased out, and costly when available.
Do you want it your way or the right way?
Old 08-02-2012, 09:12 PM   #17
My air is 20 puls, never been serviced. Filter change every 6 months. Hose condensor off, keep the dog away. It is a closed system so why would it need service unless there is a leak.
Hardway is offline   Reply With Quote
Old 08-02-2012, 09:24 PM   #18
Perhaps service is the wrong word. Maintenance describes it better. Keeping the coils clean, burners cleaned, etc.
The Following User Says Thank You to Missouri Bound For This Useful Post:
Hardway (08-03-2012)
Life Expectancy of Home Components user1007 How To Guides 4 06-01-2012 01:10 PM
Life expectancy of coil r a raper HVAC 2 01-02-2012 07:35 PM
cellulose insulation life expectancy jjmch Roofing/Siding 3 04-11-2010 10:40 PM
Rheem power vent blower motor life expectancy? windowguy Plumbing 4 09-04-2009 11:39 AM
Shake Roofing Life Expectancy daveblah Roofing/Siding 3 08-04-2009 05:41 PM
